Uprated Springs
Jason b
Bit of a strange one... wondering if anyone had some springs kicking about from a 6cyl conversion i.e. in the order of 400lb front spring rate.
I've been pricing up all new springs and dampers all round, but want to check if there is a cheaper option to try and see how far out the 400lb guesstimate that people use for front springs is...
Cheers
Jason
unlikely... but bump anyway
Jason,
You'll probably need at least 600lb front springs. I had a set of 400lb fronts on my old GTE with the 4 cylinder engine and they were really soft. I swapped these for 600lb springs and you could still bounce the front of the car easily! Maybe you'll need them even stronger than these were! .Luke.
