wicked999 Posted December 15, 2011 Share Posted December 15, 2011 hi new to this got a c20xe putting it in my cavalier cant seem to work out how to fit the 1.8 manta dizzy set up got all the bits. cant see how it bolts on and the pully is bigger than the one on the engine hope someone can help thanks Quote Link to comment Share on other sites More sharing options...
MB15 Posted December 16, 2011 Share Posted December 16, 2011 Post up sum pictures of what you have all got and it`ll be easyer to give you advice, What dizzy bracket your planning to use ect , Have a look at my project feed as i have a Mk1 cavy sportshatch with a c20xe fitted , Best of luck Kevin Quote Link to comment Share on other sites More sharing options...
wicked999 Posted December 16, 2011 Author Share Posted December 16, 2011 same set up as what you have got found the right inlet and bottom pully now .the bracket just dont seem to fit i know i need to cut some bits but not sure what to do and how it bolts to the engine Quote Link to comment Share on other sites More sharing options...
MB15 Posted December 16, 2011 Share Posted December 16, 2011 You need to cut quite a lot out of the cylinder head , ie narrow the exhaust cam cap nd bottom race to about 5 mm round , a good few mm`s of the side of the head and a wee nip out off the oil galery dowel bolt to fit , Mine is still not right so... Bite the bullet (like i done) and get the purpose made bracket from Kev Abbott on here , (£85 Inc Postage)--(check the parts for sale section) Really well made!!! It`s worth doing in the long run as mine was fouling the belt slightly after all that work! so £85 is far cheaper that belt fail - bent vavles , guides ect , If your still keen on going down the route of the normal 1.8 bracket i`ll get u sum pictures , (I have a spare head thats been cut to fit , ( a lot easyer when the head is off) Kevin Quote Link to comment Share on other sites More sharing options...
