opelmantagsi Posted April 8, 2012 Share Posted April 8, 2012 anyone got new ones or any idea what else will fit? Link to comment Share on other sites More sharing options...
opelmantagsi Posted April 12, 2012 Author Share Posted April 12, 2012 just wondering if Vectra A or B onse would do the trick? I need these to slide onto a 14mm spigot on the end of the 18mm OD rear sway bar Vectra A detail Vectra B detail someone must have an idea on this.... Link to comment Share on other sites More sharing options...
Shug Posted April 12, 2012 Share Posted April 12, 2012 I guess its part 18 you want. The bushes that the roll bar goes into are the same as a calibra. So its possible the bracket is the same or similar. Link to comment Share on other sites More sharing options...
OPEL PARTS GREECE Posted April 21, 2012 Share Posted April 21, 2012 If you are looking the 91 or 88 are available (for the moment) Link to comment Share on other sites More sharing options...
opelmantagsi Posted April 21, 2012 Author Share Posted April 21, 2012 (edited) no, thats a completely different link arrangement my links are like this, the push on the end of the sway bar, not bolt through item 35 on the following Edited April 21, 2012 by opelmantagsi Link to comment Share on other sites More sharing options...
OPEL PARTS GREECE Posted April 30, 2012 Share Posted April 30, 2012 Yeap....you are correct....BUT since the part is considered as NLS from 2001.......the old type link arrangement will work great since you are able to replace the parts in partial and not as cpl part (also you are able to mod the stabilizer height level) Link to comment Share on other sites More sharing options...
opelmantagsi Posted April 30, 2012 Author Share Posted April 30, 2012 (edited) so its possible to buy new rubbers for top and bottom? just about at the stage of getting a whole new custom made sway bar with modern link ends. frustrated at not being able to source replacement parts, especially such simple ones as this. still waiting on oil seals for my speedo drive assembly, been about a month now, how hard can it be? ARGGHHHHH! Edited April 30, 2012 by opelmantagsi Link to comment Share on other sites More sharing options...
