bones Posted April 9, 2012 Share Posted April 9, 2012 (edited) I'm looking for a 4:22 (or similar)crown wheel and pinion if anyone has one? Edited April 9, 2012 by bones Link to comment Share on other sites More sharing options...
mantaray Posted April 9, 2012 Share Posted April 9, 2012 I have a compleat axel with a 4.1:1 LSD and disc conversion, if that is off any interest. Link to comment Share on other sites More sharing options...
bones Posted April 9, 2012 Author Share Posted April 9, 2012 I'm just looking for crown wheel and pinion as I have an axle or two already in the garage and can't really afford another one. Thanks for the offer. Link to comment Share on other sites More sharing options...
OPEL PARTS GREECE Posted April 18, 2012 Share Posted April 18, 2012 931 available and also RING & GEAR PINION 35:9 (TT-AP 2888704) RING & GEAR PINION 37:10 (90009326) RING & GEAR PINION 33:9 Link to comment Share on other sites More sharing options...
bones Posted April 18, 2012 Author Share Posted April 18, 2012 931 available and also RING & GEAR PINION 35:9 (TT-AP 2888704) RING & GEAR PINION 37:10 (90009326) RING & GEAR PINION 33:9 931 avaliable? Seams a lot to have in stock. I'm after a 4:22 ratio. Crown wheel (38 teeth) pinion (9 teeth). I realise what you have done now. A 3 ratio will not fit my diff as as far as I am aware there are two types of diff unit ones for 3 ratios and one for 4 ratios. Mine is the latter. Link to comment Share on other sites More sharing options...
OPEL PARTS GREECE Posted April 18, 2012 Share Posted April 18, 2012 931 avaliable? Seams a lot to have in stock. I'm after a 4:22 ratio. Crown wheel (38 teeth) pinion (9 teeth). I realise what you have done now. A 3 ratio will not fit my diff as as far as I am aware there are two types of diff unit ones for 3 ratios and one for 4 ratios. Mine is the latter. So you are looking only for 38:9.......sorry cannot help Link to comment Share on other sites More sharing options...
