Questions Re: Mot
Thomas77GR
Hi guys, I hope you can help
My A series has failed on some of the following:
headlight beam - I have fitted new adjusters but the bulbs aren't that bright, can I replace these bulbs or are they sealed units? which bulbs would fit (don't mind if they are off another vehicle) can I fit LEDs? any links to other websites will be appreciated
number plate bulb - is that straightforward to replace?
seat belt worn - would one off another type of vehicle fit? any examples of donor vehicles I could look at?
thanks
T
Not sure what headlights you have, but generally H1 and H4 bulbs are what fit. You can get ultrabright bulbs, from halfords or other motor factors.
Number plate bulb is easy. Holder pops out of bumper. Take bulb along to halfords or motorfactor for comparison,
You can use securon belts. Fronts are 514/30
I had the same problem, 2 of my lights where as you mentioned. The my lights where sealed and the replacements I found that fit are Capri mrk 3 headlights. A alternative are these :
http://www.ebay.co.uk/itm/UK-TRAFFIC-headlights-Opel-Manta-Vauxhall-70-75-/270888755648?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item3f123a61c0
hope this helps :)
