dog321fish Posted May 31, 2012 Share Posted May 31, 2012 Hi 1983 Manta Berlinetta 1.8s Should there be a bulb inside the hazard warning (4-way) switch on the steering column? If so how do you get to replace it? The hazard warning light works on the dash when all 4 indicators are flashing. If there should be a bulb fitted is it an MOT item? Cheers Quote Link to comment Share on other sites More sharing options...
stradacab Posted May 31, 2012 Share Posted May 31, 2012 (edited) No There is no bulb in the switch, all hazzards require a tell-tale and that is already situated in your instrument pack (top left between your oil pressure and speedo like you said) so you're good to go Edited May 31, 2012 by stradacab Quote Link to comment Share on other sites More sharing options...
dog321fish Posted June 1, 2012 Author Share Posted June 1, 2012 Thanks for the reply Cheers Quote Link to comment Share on other sites More sharing options...
