Inner Tie/trk Rod End Replacement
dog321fish
Hi all
1983 1.8s Manta Berlinetta.
Is this a garage or DIY task to replace both inner tie/trk rod ends and front wheel bearings?
If DIY any pointers how to do it please.
Anyone know a reasonable garage in the Chester/North wales border area's that is prepared to work on "older" vehicles?
Cheers
Dave
pretty simple and easy task if you have tools and a Haynes manual that will tell you everything you need to know.
not sure what your tool kit comprises but from memory you will possibly need
jack & axle stands
Vise
Hammer & Punch
Socket set
Torque Wrench
Ball joint splitter (if the rod end to hub nut wont come off without spinning the ball joint on the rod end)
Possibly some spline keys
