mantaboy89 Posted July 15, 2012 Share Posted July 15, 2012 Does anyone know if it is possible to run a 2.2 cih on the 2.0 injection system? And is there any advantage to using the 2.2 injectors? Only asking as i have a 2.2 that I want to fit to my cav but no loom etc. Thanks Josh Quote Link to comment Share on other sites More sharing options...
lamchop77 Posted July 16, 2012 Share Posted July 16, 2012 It has been done and gains you about 7-8 bhp. All you need to do is redrill (accurately) for the mounting dowels and make some bigger washers for the inlet/exhaust bolts. Don't change the injectors they are the same! I might have a plenum and injectors that i drilled ready to do this. i wont use it now cos im sticking with carbs. Chris Quote Link to comment Share on other sites More sharing options...
opelone Posted July 18, 2012 Share Posted July 18, 2012 hi , ive run a 2.2 with 22 inlet ect ,, on 2.0 lite loom & ecu , to long to list set up can call on 07727137257 baz Quote Link to comment Share on other sites More sharing options...
