Manta A Front Axle Parts Wanted
sotb
I need a drivers side lower arm, and also the L shaped bits that go to the chassis rails that i have arent great! those are the main bits. i also need shocks, ball joints and bushes but i have found places to get those. anyone had any polybush experiance? is it worth it ? thanks,
Sam
Just dug it out. It is a driverside lower arm. Bit dirty so I'll clean it up. If you're interested, and I'm in a good mood, I'll even take it back to metal and coat it as well. Etch primer? Electrox? Epoxy primer? Stonechip? Take yer pick :D
Have a spare upper ball joint too. Did have a pair of lower ones, but damned if I know where they went.
As to polybushing, I did that on all bar the panhard rod, and the L brackets on front axle to chassis. Ride is fine. Firmer than my audi a3 sport. Could be the polybushes, lowered springs or adjustable koni shocks, but its fine to drive.
