cop Posted February 2, 2013 Share Posted February 2, 2013 Hi ,is anybody aware if a 3.2v6 engine petrol will run with a calibra v6 phlenuem chambers,ecu,.loom,etci am aware that a 3.0v6 can have calibra v6 parts to run? cheers steve Quote Link to comment Share on other sites More sharing options...
andyc Posted February 7, 2013 Share Posted February 7, 2013 Yes it will Once you dump all the induction from the 3.2 all the blocks are more or less the same. You can use the FWD inlet from a Cav or Calibra plus the harness and ecu but get and early ecu thats not coded. You can always make a hybrid system by using a Cav/Calibra Loom and ECU and modify a Vectra manifold by removing and blanking off the Dual Ram Flaps at the back of the manifold and you'll also need to blank off the EGR pipe on the exhaust manifold. You will also need to extend or shorted some of the wiring to make a neat and tidy job Cheers Andy Quote Link to comment Share on other sites More sharing options...
Dave Stampy Posted February 8, 2013 Share Posted February 8, 2013 On this note does any one know the year of omega v6 that didn't have a.c ? I've removed my ac compressor and need a belt that will fit cheers. Quote Link to comment Share on other sites More sharing options...
andyc Posted February 8, 2013 Share Posted February 8, 2013 for a Non AC V6 you will need a 21.36 x 1900 belt. GM Pt/No 93181718 at £18.57 + VAT Andy Quote Link to comment Share on other sites More sharing options...
Dave Stampy Posted February 11, 2013 Share Posted February 11, 2013 Ahh great cheers for that Quote Link to comment Share on other sites More sharing options...
cop Posted February 14, 2013 Author Share Posted February 14, 2013 thanks andy for info Quote Link to comment Share on other sites More sharing options...
