nickincrete Posted March 17, 2013 Share Posted March 17, 2013 can i buy a manifold flange anywher for my 2.4 head so i can fab an exhaust for my turbo setup or can anyone cut one for me from mild steel plate Quote Link to comment Share on other sites More sharing options...
16VManta Posted March 19, 2013 Share Posted March 19, 2013 If you pop over to opeltuners.com, you'll probably find a drawing for one. Quote Link to comment Share on other sites More sharing options...
nickincrete Posted March 19, 2013 Author Share Posted March 19, 2013 yes seen that but when you click on it you get what i think is cad numbers or coordinates i could probably make one using the gasket but it would take me ages to cut it out of thick sheet i would have to drill then try to saw it then die grind it here in Crete i dont know anywhere that has cad cutting, waterjet or whatever Quote Link to comment Share on other sites More sharing options...
16VManta Posted March 22, 2013 Share Posted March 22, 2013 The file name has the wrong extension and the contents are half scale. It's a DXF file but the extension is .txt. Change it to .dxf and you're sorted. Draftsight is a free Autocad compatible 2d drafting package. I use it along side ProEngineer. I can get you a price for one part but I imagine the postage is the expensive bit. Have you read this thread? You need to login to the forum. Quote Link to comment Share on other sites More sharing options...
