ventorafred Posted July 14, 2013 Share Posted July 14, 2013 Been playing up for a week or so now, but today its died, Now question is, is it a standard unit which fits all Manta B's ? or as its a 2 litre injected - do I need to find a niche one to fit? Looked for the serial number on it, nothing there at all Quote Link to comment Share on other sites More sharing options...
spiney_norman Posted July 14, 2013 Share Posted July 14, 2013 Any 1.6, 1.9 or 2.0 starter will be fine, think even 3.0 Senator/Monza ones will work! Quote Link to comment Share on other sites More sharing options...
manta88 Posted July 15, 2013 Share Posted July 15, 2013 It looks like there is a high torque and low torque versions ,you will need the 1.4kw not the 0.7kw. Quote Link to comment Share on other sites More sharing options...
ventorafred Posted July 16, 2013 Author Share Posted July 16, 2013 Just had a bit of past ownership advice will hang on till the extreme hot weather has abated, apparently it sticks when its very warm Glad to know its not a rare part though thanks chaps!! Quote Link to comment Share on other sites More sharing options...
lamchop77 Posted July 19, 2013 Share Posted July 19, 2013 Whip the starter off and take off the end plate to expose the innards,knock it gently on the side on a vice and tip it up. See if anything comes out. Auto elecy told me that the bits of brush material that wear etc can get between the magnets and the com causing it to stick...... worth a try!!! worked on my transit motor. HTH Chris Quote Link to comment Share on other sites More sharing options...
