Alternator Issues!
calmk3gt
I've been having problems with the alternator! is basically not charging the batt atall and when i'm using a few electric items it really isn't too happy! you've gotta try really hard to keep it revving! so going to have to source a new alternator and also the electric fuel pump seems to have packed in so will need a new one of those :P the alternator is the bugger though! I've got a delco-remy one on there with a part number of 002-5-26-8-45A but I'm not too sure what amp alternator i need!? and any good ones on ebay floating about? any light!!? cheeeeers!
you can fit 45 amp alternator if you wish.these were the standard item & perfectly suitable for everyday use unless you have lots of extra electrical items fitted.the delco unit has its regulator & brushes fitted internally & its better to fit a bosch type insted. these have the regulator & brushes on an easy to remove unit on the outside. also they were available as a 55 amp in the carlton 2.2 or even a 65 amp on a senator `A` 2.5 litre.all using the same mountings & wiring.if you need to go bigger then you can fit a senator/carlton 2 litre (up to about 90 amp i think but you need the matching mounting bracket & tensioner.)
