New Boxed Hella Headlamps X4 Dip+Main Same As Capri I Think
mantapaperman
hi.
brand new never used hella headlamps.
x2 dip and x2 full. flat lenses the same as the ford capri.but they do fit mantas..
the type that use the plastic hook threaded adjusters which you can fabricate out of metal bolts.
£45 per pair or £80 for all four plus post.
post estimate around £16 parcel force express 48
paypal or cash if local :)
Edited by mantapaperman
  • 1 month later...
hi..these lamps are approx 5- 3/4 inch the right ones for mantas.
the bulbs are the H1-H3 ? spot type.''same as spot lights etc''.see pics .the side light holders are not included,you should have these on your loom,
from your originals...the outers illuminate on dip and the inners and outers both illuminate on full/flash..or however you wire them to your taste..THESE ARE AN UPGRADE FROM SQUARE MANTA LAMPS THE END CAP COVERS IN PIC SHOW THE SIDE BULB HOLDER AND THE PLUG ENDS WHICH FIT STANDARD 3 PIN TYPE ON SQUARE LAMP MANTA LIGHTS ETC THESE ARE NOT INCLUDED... AVAILABLE SEPERATE AT £10 the set ,,.cheers
734155_4755711231056_1404067932_n.jpg?oh
1391976_4755712071077_662831126_n.jpg?oh
1381521_4755722991350_1498990880_n.jpg?o
1390698_4755724791395_1868767596_n.jpg?o
