gary6303 Posted April 7, 2014 Share Posted April 7, 2014 Would like to wire up two fuel pumps independant from rest of car so i can run them on their own. I have a bosch 044 as a main pump and a normal injection pump in the tank, can i fit one relay to activate both pumps but fit a switch into the wire that will run one of the pumps so i can turn it off/on as and when i want to and were i would fit the fuses in the wires, any diagrams will be a massive help as i am no electrician. Quote Link to comment Share on other sites More sharing options...
mantadoc Posted April 8, 2014 Share Posted April 8, 2014 Inline switch defeats the point of using a relay. may as well use two appropriately rated switches and wire. Would be interesting to know why because if you have not though it through especially if both pumps feed a T you can cause issues Quote Link to comment Share on other sites More sharing options...
gary6303 Posted April 10, 2014 Author Share Posted April 10, 2014 Was going to use the standard fuel relay to feed my intank fuel pump that feeds my swirl pot and then a switch to turn on my 044 pump thats feeds the c20let engine. Quote Link to comment Share on other sites More sharing options...
