Red Top Round Coil
cop
HI started engine up last year running ok, tried starting this year it fired up two weeks ago,but I haven't any spark,to check coil do I take ohms reading from negative to king pin and then + to king pin? I believe my coil up the duff it has Bosch wb 0221600 060 s3. WILL A COIL OF A LET WORK .with the letters WT, cheers steve
not sure whats happened, it didn't spark last week ,dismantled coil again and took readings off it ok. put back together sprayed some carb cleaner in and it fired up?///////////.
rob do you have the calibra electrical drawing showing ecu , etc. if you do can you send me that please,i think I going to put some extra earth straps on?
