NickSed Posted June 3, 2014 Share Posted June 3, 2014 I have a '87 GTE with the type of rear ARB drop link below and I'm wanting to upgrade to polybushes but cannot find a kit for these only the ARBs with the holes in the end. I've nicked the picture from a different thread, it's a Y shaped bracket with a hole in the bottom and the ARB goes through with a bush. Just wondering if anyone has found where you can get these from or if you can straight swap to the ARB with the holed ends in? Thanks Quote Link to comment Share on other sites More sharing options...
andyc Posted June 3, 2014 Share Posted June 3, 2014 The bush that the roll bar goes through is the same as the ones used on 4x4 Cavalier & Calibra but i know OE ones are now quite hard to get these days but at least it gives you another model to look at Cheers Andy Quote Link to comment Share on other sites More sharing options...
Denis K Posted June 4, 2014 Share Posted June 4, 2014 I had this same problem trying to find these. They are the exact same bush as an Omega, calibra or any gsi cavalier once it has independent suspension on the rear like the calibra has. The 4x4 models would have the same bush too I'd imagine as has been already stated. I know this as I have an omega scrapped and I took the bush off the omega to compare with the manta bush and they are the same 100%. I bought mine off ebay. I cant remember the name of the seller but I had a quick look there and there is a few different sellers doing them now. Go into the suspension section for an omega and keep going through the list of parts and you will come across them eventually. Dont bother trying to get them from the main dealer as they dont sell them sepaately. Cheers, Denis Quote Link to comment Share on other sites More sharing options...
NickSed Posted June 4, 2014 Author Share Posted June 4, 2014 Cheers guys, I'll have a look on there now. Quote Link to comment Share on other sites More sharing options...
opelmantagsi Posted June 13, 2014 Share Posted June 13, 2014 the real name for those is "drop links" originals hard to find alternate ARB and drop links on some models, but dont seem to be cross over to body mounts Quote Link to comment Share on other sites More sharing options...
