smghd Posted July 1, 2014 Share Posted July 1, 2014 My '73 needs a new clutch as the slip is getting worse as the weeks go on. Precision Clutch have clutch kits on the shelf but they have a standard and a heavy duty listed for the 1900, without taking it apart first I don't know which is fitted. I know the heavy duty clutch has a larger diameter to the std clutch but can it be fitted to a standard flywheel? i.e the clutch cover/pressure plate has the same hole pattern and spacing. obviously I'd rahter have the clutch kit ready to go when I start the job but at the moment looks like I'll have to strip her down then order the clutch, or order a std and hope it's the right one (or both and return the one that I don't need but thats a extra £60+vat I don't have to spend out, lus return postage) Quote Link to comment Share on other sites More sharing options...
611 Posted July 1, 2014 Share Posted July 1, 2014 When you say heavy duty clutch, what size is the clutch plate? Normal manta is 8" and i think it was the same size for the 1.6 and 1.9 (but put me right if im wrong) you can get a 9" but you will need a bigger flywheel from the Monza, but only needed if you have lots more power. Ran standard AP clutch in mine and was running a 2.1 Andy Quote Link to comment Share on other sites More sharing options...
Beaker Posted July 2, 2014 Share Posted July 2, 2014 I have a clutch disk, no bearing or pressure plate, any use? Quote Link to comment Share on other sites More sharing options...
611 Posted July 2, 2014 Share Posted July 2, 2014 I have a clutch disk, no bearing or pressure plate, any use? I have a spare pressure plate and bearing, could be a good match! Quote Link to comment Share on other sites More sharing options...
smghd Posted July 2, 2014 Author Share Posted July 2, 2014 Thanks for the offer but win the slipping I'd deduce it's the pressure plate that's a little weak so full kit. Precision clutches have a 200mm & 228mm in stock. As the she's standard I'd deduce that is has the std fitted on std flywheel. Just wondered as changed other clutches that would have room for a larger plate under the cover if they do them (didn't look as mates' cars). At least thus should be a little easier than those as the drive is at the right end of the car... Quote Link to comment Share on other sites More sharing options...
611 Posted July 3, 2014 Share Posted July 3, 2014 If you have the 4 speed box i dont think there is much space for a bigger one, but if you have the 5 speed there is a lot of space for a bigger one but you will need the bigger flywheel. And the 5 speed box is a bugger to got off unless you drop the suspension down. i think the 4 speed is easy as is. Steve, where in Hampshire are you? im in bournemouth!! Andy Quote Link to comment Share on other sites More sharing options...
