vxlgsi Posted July 31, 2014 Share Posted July 31, 2014 (edited) Firstly hello everyone :0p Does the 2.2 cih clutch fit the 215mm 2.0 flywheel? Covers both appear to be 4 bolt I have 2 oe flywheels and both are moded for 6 bolt clutches so possibly a step has been removed if there ever was one? Ie does it just have a a bigger friction plate? Thanks Edited July 31, 2014 by vxlgsi Quote Link to comment Share on other sites More sharing options...
moodoo Posted July 31, 2014 Share Posted July 31, 2014 This thread might help.... http://forums.mantaclub.org/topic/36442-clutch-advice/ Quote Link to comment Share on other sites More sharing options...
vxlgsi Posted August 1, 2014 Author Share Posted August 1, 2014 Thanks for the link, I had seen that thread and some others but I need to be sure. Can anyone tell me the step height between the cover mounting face and the friction face on a 2.2 flywheel? Quote Link to comment Share on other sites More sharing options...
vxlgsi Posted August 1, 2014 Author Share Posted August 1, 2014 If anyone can help ill do you a good deal on a nice lightweight steel flywheel. Quote Link to comment Share on other sites More sharing options...
vxlgsi Posted August 2, 2014 Author Share Posted August 2, 2014 Any other forums I can try? Quote Link to comment Share on other sites More sharing options...
lamchop77 Posted August 5, 2014 Share Posted August 5, 2014 Step height from memory is 2.5mm, might need to check tho!! The 2.2 won't fit the std 2.0 flywheel. Best to have a steel flywheel made to use a calibra turbo clutch. Hth Chris Quote Link to comment Share on other sites More sharing options...
