C20Xe Connectors
Ems
HI, ems are you after actual new connector or want to know where they go the Injector connectors are on the injector rail itself and the knock sensor, has two pin, that come of a mini loom that connects and combines both knock sensor and idle control valve.
if you don't have the mini loom you can get one off ebay, none on at the moment as they go like hens teeth just keep looking they do come on, if no luck you could get make your own mini loom let us know and i can provide details where to buy the standards connectors from (consists of 2pin ivc, 2pin knock sensor and 4 pin plug)
Try this website, best thing is to ring them and tell them is a redtop they will know what you want.
http://www.simtekuk.co.uk/index.php/automotive_connectors/junior_power_timer_connectors/?k=:8:1630::17:130544
if you want i am going myself next week to buy some connectors i could show them a example of the injectors connectors so they can relate for you.
  • 3 weeks later...
Quick update.  I got junior timer connectors, which are a perfect fit for the injectors.  I'm also using junior power terminals in various existing connectors as I'm changing some of the wiring.
