Wheel studs loose in hub.
tooler
Have manta A and noticed front wheel comes loose, not the nuts but the studs are loose in the hub. Thought wheel bearing was issue, but now know it's studs. Is there easy fix for this, or what do I need. New studs or hub. Any info appreciated.
Yea, I thought it was strange. I felt it in steering when braking first. And checked it out thinking wheel bearing. Replaced it and still loose with wheel all tightened back up. There's play in the wheel. Studs loose where the spline part is pressed in to hub.
If the studs are loose in the hub where the splines are. It sounds as though the holes in the hub have become elongated. Sounds like a case for a new hub and studs. You could weld the studs to the hub. But that's a bit rough and it's a bit of a chance to take as far as safety is concerned. HTH
Cheers
Davy
