Aditi Posted April 27, 2016 Share Posted April 27, 2016 Good Evening, I bought an 'Castrol Transmax' Dex 3 oil to change and refresh the oil fluid, it should be match? How mach quantity enters the gearbox system? Thanks, Aditi Quote Link to comment Share on other sites More sharing options...
Scribe of Lincoln Posted April 27, 2016 Share Posted April 27, 2016 Hi Aditi, I've always used Dexron 2 in my Mantas - recommended by an engineer who used to sell Manta's back in the 80s. I would recommend that you also change the gearbox filter cartridge and the oil pan gasket while you are at it. Expect to use around 3.4 litres to re-fill. When checking the level of the oil, the distance between the "add" and the "full" mark on the dipstick is 0.56 litres. When the engine is at full operating temperature, the oil level should read as "Full" against the dipstick. Avoid over-filling! Regards, Scribe Quote Link to comment Share on other sites More sharing options...
Scribe of Lincoln Posted April 28, 2016 Share Posted April 28, 2016 Hi Aditi, As requested, here are a couple of photos of the front and back of the auto gearbox filter cartridge. If you are searching on line, I believe that the same cartridge is fitted to the Rover SD1 (not sure if you'll have many of those rattling around in Israel but you may be able to track on e down on E-bay. You need to look for the filter for a GM180 transmission. Good luck! Scribe Quote Link to comment Share on other sites More sharing options...
