vauxhallkeith Posted January 31, 2018 Share Posted January 31, 2018 Looking for a set off disc spacer to fit xe brakes to manta. Cheers Link to comment Share on other sites More sharing options...
mantasrme Posted February 1, 2018 Share Posted February 1, 2018 Instead of the spacers you can just use Audi discs as they are the right size and offset to line up with the astra calipers, they do need the centre bore opening up and 4 new mounting holes adding (but so do the astra discs even with spacers). They work out much cheaper than going for spacers. I used to get the alloy spacers made and they were up to £90 a set plus then the astra discs and machining would total the lot out around £160 where as i now have audi discs modified and they are £85 a pair once done Link to comment Share on other sites More sharing options...
