Snowy Posted August 5, 2018 Share Posted August 5, 2018 (edited) In the garage i have the following surplus to requirements; A 20NE complete. Also includes loom, ecu, airflow meter etc. So apart from the airbox everything you need to make it run. To any member £120 plus delivery. But collection preferred. A 20SEH. The head was removed for inspection but all is good. This is just the bear engine. But if you combined it with the above engine all you would need is an ECU (£30 off ebay) to have a fully functioning SEH. To any member £80 plus delivery. But collection preferred. An 18S opel manta engine. Heard this running before removal. The dissy is in the garage but I'm not sure about the inlet manifold. It's fitted with the sump, mounts etc. But these would either need to be exchanged or they will be removed. To any member £40 plus delivery. But collection preferred. Thsnks Edited August 5, 2018 by Snowy Quote Link to comment Share on other sites More sharing options...
Jonohendo Posted August 25, 2018 Share Posted August 25, 2018 Are the all ohc engines Quote Link to comment Share on other sites More sharing options...
Snowy Posted August 25, 2018 Author Share Posted August 25, 2018 2 hours ago, Jonohendo said: Are the all ohc engines Yes. Quote Link to comment Share on other sites More sharing options...
