Monaco Blue Posted July 19, 2019 Share Posted July 19, 2019 Tidy looking Sportshatch in copper. One of the best colours inho. Unfortunately, it looks like it will need a bit of TLC according to the latest MOT list before it passed 2nd time around : Repair immediately (major defects): Nearside Rear Suspension component mounting prescribed area excessively corroded significantly reducing structural strength hole/s in inner sill within 30cm of rear axle sway arm mounting. highlighted / marked with chalk (5.3.6 (a) (i)) Offside Front Suspension component mounting prescribed area excessively corroded significantly reducing structural strength hole in vehicle bulkhead within 30cm of shock-absorber mounting, hole highlighted / marked with chalk (5.3.6 (a) (i)) Monitor and repair if necessary (advisories): Oil leak, but not excessive (8.4.1 (a) (i)) Fuel Pipe/s corroded main feed pipe from fuel tank () Brake pipe corroded, covered in grease or other material various pipes throughout (1.1.11 (c)) various rubber bushes are deteriorated, gearbox mountings and various suspension components brake master cylinder is corroded vehicle underside has multiple patches of surface corrosion throughout. https://www.ebay.co.uk/itm/1980-Sports-Hatch-2000s/283552328183?hash=item42050929f7:g:ibAAAOSw-ZZdMJjz Quote Link to comment Share on other sites More sharing options...
