A Series Manta Parts
MrCarlos
Having now stripped the Blue Car and the Red car I have Lots of Parts available 😊
Discount for multiple buys
Everything can be shipped
Collection from Burnley, Lancashire is welcome
Loads more bits available - just ask for what you may need!
Fuel Tank - Sound, no leaks, surface rust only £100
Front Subframe / Suspension Complete (One lower rear arm bit of rust, rest is sound) £100
Headlining Rods £20
Pedal Box £30
Upper Rear Panel £40
Starter Motor £20
Cardboard Trim for rear of boot £25
Bulkhead Rubbers £40
Steering Column £30 - Steering wheel in fair condition, Hazard switch has missing stalk and broken wire top and bottom bearings good
Wiper Motor and linkage good working order £40
Clutch Cable £10
Locking Fuel Cap with 2 keys £25
Locking Fuel Cap 1 Key £20 needs seal
Ignition Switch £20
Bonnet Release Cable £10
Throttle Cable 1.6 engine £15 ( I have 1.9 version too same price)
Bonnet Catch £15
Boot Lock with key £20
Pair front door handles one key which works drivers side, some pitting etc to chrome £25
Dash Clocks 1.6 Engine £20
Wiper Arms parallel splines type £15
Dash Vent set £20
Glove box lid £20
Heater box with matrix and control valve - flows water well and valve works £40
Rear Lights set nice condition complete with gaskets £100
Gear lever £25
Fuel tank filler neck  metal surface rust but sound £15
Pair door switches £10
Floor pan grommits - £10 the lot
Rear view mirror £20
Washer bottle (unknown if pump works) £15
Interior light great condition £10
Thermostat Housing £25
More to come!!
Edited by MrCarlos
  • 2 months later...
28 minutes ago, te2800 said:
Do you still have the rear lights and front grille set for sale
Yes i still have the rear lights above and also a good grille set from the yellow car, thats £100
Can post it all for £20 mainland uk
