niall.oreilly Posted August 6, 2020 Share Posted August 6, 2020 The alignment adjusters on my 1988 Manta 2.0E are worn out and won't hold the headlight in position. ANy suggestions on where I can get replacement set? Link to comment Share on other sites More sharing options...
hoobby Posted August 6, 2020 Share Posted August 6, 2020 On 16/08/2019 at 06:26, hoobby said: . Thanks rutts and kev.bolts m5 Spring 7.1mm od wire dia 0.8mm should give 5.5mm id.and some brass screw cups and m5 nut or wing nuts. hope this helps 2 Link to comment Share on other sites More sharing options...
