seanpren Posted March 18, 2023 Share Posted March 18, 2023 Hey all Have any of you lads fitted a twin throttle cable setup to your manta on twin carbs? I've bought a set for mine which is an XE on twin dellorto 45s. Haven't got out near the car yet but just wondering do youndrill 2 holes in bulkhead, fit cables to block on pedal and then trim the cable to desired length? Do you need to crimp the cable adjusters onto the cut end of the cable then? Sorry for the longwinded questions lol Forgot to add the pics Quote Link to comment Share on other sites More sharing options...
Moonmonkey Posted March 19, 2023 Share Posted March 19, 2023 (edited) There are 2 cable holes already in the bulkhead. There is a bung to the right of the standard cable that just needs to be removed To modify the pedal, grind off the standard cable retainer, and round off the pedal to fit the new twin cable retaining block (don’t cut the end of the pedal off😊) The cable just goes through the adjusters I’ve never crimped them to the end of the cable outer. Edited March 19, 2023 by Moonmonkey Re-read the question 😊 1 Quote Link to comment Share on other sites More sharing options...
seanpren Posted March 19, 2023 Author Share Posted March 19, 2023 Ah perfect so thanks 👍 Quote Link to comment Share on other sites More sharing options...
