youthofbritain Posted September 8, 2009 Share Posted September 8, 2009 Having trouble deciding which carburettor road to take. Just finishing my Kadett C Coupe project, with C20XE in it, and gettin low on the old spangola. Any of you guys got R1 carbs? How do they fair out to a pair of 45's?? Cheers James Quote Link to comment Share on other sites More sharing options...
midasmesh Posted September 9, 2009 Share Posted September 9, 2009 Link here about r1's and carbs. http://forums.mantaclub.org/topic/22918-xe-conversion-carb-clearance-issues/page__hl__r1%20carbs__fromsearch__1 Heres a link to a Total vauxhall feature on Bike carbs. http://www.totalvauxhall.co.uk/resources/totalvauxhall/TOV64.tech60697.pdf Seems bike carbs are becoming the more cost effective option nowadays due to the cost of Webers and manifolds. Unless you can drop on a cheap set up. Quote Link to comment Share on other sites More sharing options...
vauxsenb Posted September 9, 2009 Share Posted September 9, 2009 Go for the R1's, I've previously been on Webers and now on R1's and the Yamaha design carb's stay in tune so much better than the Webers and as already pointed out are far cheaper to purchase with an inlet manifold from Bogg Bros for £170 so go calculate. Spent most of last week chasing a MK1 Astra around Nurburgring which was on Redtop/R1's and it was pulling like a train. Just one note of caution, it would seem there is a possible issue regarding the mounting of these carbs to the inlet manifold (almost every car on the BH2N run using R1's had experienced niggles) and it may be well worth using the genuine Yamaha inlet mounting rubbers to avoid the carbs separating from the manifold or silicone hose supplied by Boggs. HTH, Cheers, Colin. Quote Link to comment Share on other sites More sharing options...
youthofbritain Posted September 9, 2009 Author Share Posted September 9, 2009 cheers for the info guys Quote Link to comment Share on other sites More sharing options...
