Rev Counter
shooie811
I'll assume you have a B with points?
Still doesn't really matter. You need to take a feed from the green wire on your coil all the way to the back of the dash behind the rev counter. There's also usually a white wire (I think) in the same connector that goes somewhere. Someone else will pop in and tell you if that's to ignition live or whatever.
To make it look factory (although you can find a spade version of the loom) you would need on of these male female things.
Green female pulls of coin and connects to male. Female from Y or is it T piece goes onto coil and stray end to rev counter.
