Jason b Posted September 26, 2010 Share Posted September 26, 2010 I am desperately in need (you guessed it... sticky bonnet cable... not latched quite right... small bump was enough to lift it proud of the nosecone and WHACK) of a pair of bonnet hinges for a mk1 cavalier saloon (but I'm imagining they are the same as manta B ones?) (Also if anybody knows of a good or easy method of replacing them - looks like they are crush rivetted in or similar - then that would also be of use!) Thanks very much in advance! Jason Link to comment Share on other sites More sharing options...
Mick Posted September 26, 2010 Share Posted September 26, 2010 (edited) I have a pair on a Mk1 Cav Im breaking. I can get them off for you in the next day or 2, will see if I can get the mounting bracket too. If not a small grinder like a dremmel can get in there to grind the stamped end off, easy to replace with nuts and bolts then... Edited September 26, 2010 by Mick Link to comment Share on other sites More sharing options...
Jason b Posted September 26, 2010 Author Share Posted September 26, 2010 Awesome, thanks! the sooner the better really as I will be moving from dorset to southampton at the end of the week. PM me how many pennies you would like for your troubles Thanks Jason Link to comment Share on other sites More sharing options...
Mick Posted September 26, 2010 Share Posted September 26, 2010 Will do, only about 20 quid inc postage but will confirm when I get them off tomorrow... Link to comment Share on other sites More sharing options...
Mick Posted September 26, 2010 Share Posted September 26, 2010 PM me your address and I can get the whole thing sorted tommorrow Link to comment Share on other sites More sharing options...
