What Will I Need
michael d.IF 3
hi iam new this crack but iam after buyin a 1986 manta gte its running fine but i want to get a c20xe running in it just wonderin what other parts i need i already have a cos cast xe engine out of a gsi cav with the full wirin loom and ecu.i also have 1.8 manta sump and pick up pipe. but was wonderin do i now only need to get 1.8 mounts and 1.8 gear box or is there many other little bits i need .(also i was told the 1.8 gear box,s only come in 4 speed is this true) .thanks
Edited by michael d.IF 3
Hi there, 1.8 box is a five speder and will mate to the XE, i think you need to mix and match clutch cover and plate, not sure which ones tho, i have a set of 1.8 alloy mounts if your interested, if you join up to the club there is a hell of a lot of info on this site, i joined about a week ago and once registered as a member there are a lot more sections and "how to" pages, well worth it, you will find all the answers you need , good luck.
Hi mate, join the club and not only will you get all the tech info you need but cheap oil and batteries direct from vauxhall :thumbup
2 posts the same Kev!!!! Hope you ain't pi##ed ! Watch you don't land on your face..................:lol: :lol:
Curt
Edited by cact1972
