johnboy Posted November 29, 2010 Share Posted November 29, 2010 Does any one know the free length of the front springs from a 1973 A series manta 1.9. The reason i ask is i have odd springs on the front of my car, one is 9 1/2 coils and quite thin in diameter and the other is only 8 coils but fairly thick in diameter, almost 2mm thicker. The car sits way high on the front so i have put new springs on from ces and it still sits way too high, in fact so high that when you lower the car back down you still can't get the bottom shocker bolt through. This is the second set i have tried, they fit perfectly just too high so i am contemplating cutting a coil or two off them to bring the ride height down so could do with a length for standard ride height or slightly lower ride height please. I did notice on the box that the springs where for manta 71-84 1.6 or 1.9, i thought 71-75 a springs where different to later cars??? any help appreciated or if you have a spare set to sell let me know, Cheers for now John Quote Link to comment Share on other sites More sharing options...
OPEL PARTS GREECE Posted November 30, 2010 Share Posted November 30, 2010 Does any one know the free length of the front springs from a 1973 A series manta 1.9. The reason i ask is i have odd springs on the front of my car, one is 9 1/2 coils and quite thin in diameter and the other is only 8 coils but fairly thick in diameter, almost 2mm thicker. The car sits way high on the front so i have put new springs on from ces and it still sits way too high, in fact so high that when you lower the car back down you still can't get the bottom shocker bolt through. This is the second set i have tried, they fit perfectly just too high so i am contemplating cutting a coil or two off them to bring the ride height down so could do with a length for standard ride height or slightly lower ride height please. I did notice on the box that the springs where for manta 71-84 1.6 or 1.9, i thought 71-75 a springs where different to later cars??? any help appreciated or if you have a spare set to sell let me know, Cheers for now John This does not have to do with the number of coils or height unloaded but from the strength or the mm of each coil Quote Link to comment Share on other sites More sharing options...
costasa Posted November 30, 2010 Share Posted November 30, 2010 Does any one know the free length of the front springs from a 1973 A series manta 1.9. The reason i ask is i have odd springs on the front of my car, one is 9 1/2 coils and quite thin in diameter and the other is only 8 coils but fairly thick in diameter, almost 2mm thicker. The car sits way high on the front so i have put new springs on from ces and it still sits way too high, in fact so high that when you lower the car back down you still can't get the bottom shocker bolt through. This is the second set i have tried, they fit perfectly just too high so i am contemplating cutting a coil or two off them to bring the ride height down so could do with a length for standard ride height or slightly lower ride height please. I did notice on the box that the springs where for manta 71-84 1.6 or 1.9, i thought 71-75 a springs where different to later cars??? any help appreciated or if you have a spare set to sell let me know, Cheers for now John Maibe this gonna help, is in german but you can translate Springs Front Springs rear Quote Link to comment Share on other sites More sharing options...
upk Posted November 30, 2010 Share Posted November 30, 2010 Not from experience but i do believe a cut spring is an MOT fail!! If you want a pair of second hand 1.9 manta A series springs then give us a shout.........i have a full set here. and yes they are thinner section steel! Quote Link to comment Share on other sites More sharing options...
