Malpassi Adjustable Fuel Pressure Regulator
mantasrme
Here we have a Malpassi adjustable fuel pressure regulator
It came from a running Manta GTE a few months ago that was running fine.
Ideal to get the fueling just right with a modified engine.
Looking for £20 colleced from Harrogate N,Yorkshire
Or £24 delivered to mainland uk
Don't think this will work on a carb'd engine, it's meant for injection.
Upping the fuel pressure only works on injection, as too high a pressure can flood a carb.
Normally on big carb's you need more flow from the pump.
Do you have an electric fuel pump fitted or the standard mechanical pump?
I might have an Elec pump in the garage
Had a look and don't have any pumps left, although i can't remember where the last one went :blink:
I do have a filter king/ adjustable pressure regulator like this
But you don't normally need to adjust the pressure down on a weber carb when using a facet pump, as they self regulate.
