1.8 Engine Mounts
nova-baz
hi ive got some 1.8 engine mounts but not sure how to tell which 1 goes which side! one is flat on the side that mounts to the block and one has a step! cant some one help please also what is the difference in a 1.8 oil pick up pipe and a xe one? cheers
Edited by nova-baz
they only fit one way round, try them on and you will see they fit flat to the block if correct
Xe vs 1800 pick pipe?
Same as but the 1800 one is 5mm deeper into the sump so don't worry about it and keep a check on your oil :thumbup
Cheers
Kev
