pma Posted June 13, 2011 Share Posted June 13, 2011 Hi guys, in the last few weeks i've seen a few posts re top and bottom rad hoses (for Manta B's)obviously no one lists these any more,but i may be able to help out.GATES do a product called VULCOFLEX,which is hose with wire running through it.Basically you can bend this into shape,and after hot water has been run through it a few times,the hose retains the shape to which it was bent.So as long as these hoses are a single hose (ie,no splits or joins leading off them)i may be able to help .Can anyone tell me the i/d of these hoses (at both ends please as sometimes the same hose can have different i/d's at either end),and also the total length please.If you can let me know on my works email (as i have all the info/catalogue's there)that would be great; pansell@fpsdistribution.co.uk cheers Quote Link to comment Share on other sites More sharing options...
