Hatch Injection Tank Needed
mantaboy89
You can also mod yours with a 12mm pipe.......
how. ? no good without a swirl pot inside or remote as a last measure. even proper tanks WITH a swirl pot can sometimes be a bit tempermantal when low on fuel (vectras in particular seem to)
i have a perfect injection tank.its just been `RENEWED'. this is a process of repairs & epoxy sealing of the inner & outer with a lifetime guarantee. i am using carb so if you can get me a carb tank RENEWED i would do a swap if you want .
Very Very easily
You need an 12mm copper agle and a man who will be able to solder it....after a very good clean with water......for ex a refrigeartor repair man do the work great.....as i know the soldering is done with a mixing tin and silver
Some cheap/easy mods are made only by replacing the fuel tank sensor with a 20E one and fixing the length of the feed line (the tank has to be at least in midle .......but in low tank fuel......too many feed problems......
Edited by OPEL PARTS GREECE
