surfup* Posted December 3, 2011 Share Posted December 3, 2011 Hi All, Could you give me some advice, I am thinking of stripping down the front calipers, would i require to replace the seal set as a standard thing to do or should I look at the set that is coming out and if all looks well just put them back in place? I do appreciate the advice. Cheers Quote Link to comment Share on other sites More sharing options...
Kevin Abbott Posted December 3, 2011 Share Posted December 3, 2011 If you are taking the time to strip and refurbish the caliper then I would put a new seal kit in. They are cheap enough to not take the risk using the 20+ year old ( maybe ) seals Get some proper rubber grease too Cheers Kev Quote Link to comment Share on other sites More sharing options...
dog321fish Posted December 3, 2011 Share Posted December 3, 2011 Hi I would recommend a new seal set, what is the point of stripping down just to clean and put the same ones back in? They will probably have age hardened or perished anyway. Pointless stripping down unless you have a new set to fit. You may like to replace the caliper sliders at the same time? HTH Dave Quote Link to comment Share on other sites More sharing options...
