Door Pins, Window Rear Channel, Window Top Stop
richm
Hi all,
I'm after the following for Manta B coupe...
* Set of door hinge pins (genuine GM items) 8mm x 60mm
* Rear channel for passenger side door glass (good condition with good rubber/felt insert)
* Window stop (little bracket with rubber at bottom, stops window winding up at max height) - need 1 but will take a couple if available
Cheers,,, Rich
Edited by richm
Great, thanks Rob, appreciate it.
And thanks Stradacab for the info re the stops - I'd assumed they were identical, so this probably saves some confusion/frustration later (had enough of that already adjusting the door windows but finally got it right :))
