mantapaperman Posted June 16, 2012 Share Posted June 16, 2012 (edited) hi all. bought a C20XE with ecu and loom. its a dizzy type but the chap i got it of thinks it had a cat? how do i get round this as i wont be fitting a cat obviously..but the ecu will be looking for a signal off the oxy-lambda sensor. will i have to fit a lambda sensor in the exhaust? or should i try and source a ecu from the early 20xe-j?any advise greatly appreciated Edited June 16, 2012 by mantapaperman Quote Link to comment Share on other sites More sharing options...
redmanta xe Posted June 16, 2012 Share Posted June 16, 2012 yes i did fit one to mine u can get early loom and ecu from a 20xe ( u dont need a oxy lambda sensor u have a c20xe ecu and loom u need fit a oxy lambda sensor if use this ecu u will have to fit one in the exhuast Quote Link to comment Share on other sites More sharing options...
rutts Posted June 16, 2012 Share Posted June 16, 2012 it will run with out sensor but i would fit one, i put mine in the four branch manifold just where they all collect into single pipe. you can buy the threaded bit to weld into your pipe off ebay. Quote Link to comment Share on other sites More sharing options...
johnboy Posted June 17, 2012 Share Posted June 17, 2012 You already have the loom and ecu so use that, buy a threaded plug from an exhaust supplier and weld it into the down pipe where all 4 pipes meet up, it will read the exhaust gases and help the ecu regulate the fuelling, dont be tempted to just tape up the connector to the lambda sensor or it would flag up a fault in the ecu and you would have poor running and it may go into limp mode. Quote Link to comment Share on other sites More sharing options...
Dom400 Posted June 18, 2012 Share Posted June 18, 2012 Hi, Just been sorting out my new engine and fixing this issue, the C20XE engine should be run with a Lambda sensor to get best results. But you can bypass the sensor and the ECU will run fine without it as long as no other major mods have been done to the engine that affect its fueling. If you are running without a Lambda sensor make sure pin 20 is earthed, this tells the ecu is not there and not broken! Laters, Dom Quote Link to comment Share on other sites More sharing options...
mantapaperman Posted June 20, 2012 Author Share Posted June 20, 2012 thanks guys . Dom400 do i cut the wire coming out of the ecu plug and say earth it with an eyelet on one of the ecu mounting bolts? or do i eart the other side of the cut wire that goes to the lambda sensor? er no cos there wouldnt be a sensor connected would there so it wouldnt matter..anyway thanks Quote Link to comment Share on other sites More sharing options...
Dom400 Posted June 22, 2012 Share Posted June 22, 2012 thanks guys . Dom400 do i cut the wire coming out of the ecu plug and say earth it with an eyelet on one of the ecu mounting bolts? or do i eart the other side of the cut wire that goes to the lambda sensor? er no cos there wouldnt be a sensor connected would there so it wouldnt matter..anyway thanks Hi, If you look at the wiring diagram for the C20XE there is a wire from pin 20 to earth which states "NOT WITH P32" so if you decide to run with out a Lambda you need to activate this pin. So on my car untill i fit a lambda sensor I have bridged pin 20 to 42 (black & red earth). Should really run a lambda sensor! But I am a bit broke at the moment after replacing the engine so this is just a temp solution, I suggest you also get a lambda sensor fitted! Laters, Dom Quote Link to comment Share on other sites More sharing options...
mantapaperman Posted June 22, 2012 Author Share Posted June 22, 2012 thanks for the info much appreciated.. Quote Link to comment Share on other sites More sharing options...
