BEEDZ Posted June 18, 2012 Share Posted June 18, 2012 Hi im after an air box to fit a 1977 1.9 manta the one with the hole in the centre to hold it ontop of the carb and sits on the round rubber seal thanks. Im in Hull but do get about a bit Link to comment Share on other sites More sharing options...
stradacab Posted June 18, 2012 Share Posted June 18, 2012 You had better let us know which carb you wish it to sit atop of. I'm guessing Varajet but '77 may be a bit early for that? Link to comment Share on other sites More sharing options...
BEEDZ Posted June 19, 2012 Author Share Posted June 19, 2012 Yeah sorry it had a weber fitted in 1994,hope this helps i will post a photo later thanks. Link to comment Share on other sites More sharing options...
BEEDZ Posted June 19, 2012 Author Share Posted June 19, 2012 (edited) Hey up this time i will try and do it right like i should of done first time.Its just that i think every body should know what im thinking Dia;150mm there is a code for a filter box ;DGM 9892S CARTRIDGE PC102 GN 08960880 Ive tried google but nothing hope this is more informative thanks again. Edited June 19, 2012 by BEEDZ Link to comment Share on other sites More sharing options...
spiney_norman Posted June 19, 2012 Share Posted June 19, 2012 Looks like a Weber with an adapter plate to take the air filter box for the original Zenith. Link to comment Share on other sites More sharing options...
BEEDZ Posted June 20, 2012 Author Share Posted June 20, 2012 Thanks for the info Rob if i dont have any luck with a filter box a may try a K&N filter and see how that goes? cheers. Link to comment Share on other sites More sharing options...
