Some Items I Required To Finish My Car
robah
Has anyone got any off these items or info on obtaining them.
1. 20XE later type (if it makes any difference?) upper Alternator belt adjustment arm/bracket, the item the upper bolt from the alternator fits in to adjust the belt. I have one but can't find it. Also lower front bush for bottom bolt please.
2. Hand brake cable to suit the disc conversion as the standard Manta type is approx 6-8" too short. my rear calipers are frod serria type and mounted at the rear of the hub.
3. Correct number for the clutch cable to suit the 5 speed getrang gearbox, just noticed (after purchasing a few months ago) I have been supplied the wrong one from an ebay seller, I need to send it back with the correct info. Is this the correct type http://www.ebay.co.u...=item3378537e12 ?
4.Lower Bellhousing plate to fit the 1.8 Manta gearbox, just realised mine is a 2.0L CIH which is not suitable
Thanks for looking and I can pay by PayPal and I will be at Billing this year.
Rob
Edited by robah
double rose jointed adjuster is the go for the alternator, did this on mine.
Mk4 Golf GTi rear handbrake cable to Manta centre cable triangle if your using girling 38 calipers
Thanks for the info mate, I will look in to the advice.
Update
Rose joint adjuster, great idea and will look in to doing it that way
Hand brake cable requires the rectangle hook type to fit on the mechanisim
Rob
Edited by robah
because I used a 125 amp alternator with side drafts I had to fit the alternator lowering bracket, sourced from either eurocarb or QED I think?
the 125amp alternator had a bigger lower bolt mount and the offset of the alternator lower mount was not quite right so got delrin inserts made, then filled down the outer face until the pullies lined up
big earth cable off the top mount back onto a tapping on the block previously used by the plastic cooling manifold pipe
Some very nice work there (along with the car :thumbup )
As I am not near my car location (150 mles) and I can get the parts close to where I am at the moment (bearing specialist), are the eye ends and threaded rod M8 (13mm head). Thanks again in advance for any info.
Rob
