mrNick Posted July 30, 2012 Share Posted July 30, 2012 hi guys setting up and checking the manta for drift ...discoverd a descrepency and need to know the correct measurement from centre offront wheel to centre of rear many thanks Quote Link to comment Share on other sites More sharing options...
simon p Posted July 30, 2012 Share Posted July 30, 2012 2517mm Quote Link to comment Share on other sites More sharing options...
dtm Posted July 30, 2012 Share Posted July 30, 2012 (edited) sorry to go off topic mrNick but what chnages would you normally do to a manta to set it up for drift?Camber, castor, antiroll bars? Any info at all would be greatly appreciated! thanks Edited July 30, 2012 by dtm Quote Link to comment Share on other sites More sharing options...
mrNick Posted July 31, 2012 Author Share Posted July 31, 2012 drift setting usually have about 1.5/2 degrees front camber ,6 degrees caster and the rear setting really depend on how much power you are running ,some with big powere dial in a tiny bit of rear positive camber so when the power is put down they even up to zeroish so you get even tyre wear and contact... the manta with a zero degrees rear set up could do with plenty of ponies to break the back out ..imo also the front could really do with a coilover conversion ..the rear could stay soft for drifting cars going to Simon to be looked at so ...watch this space !! whilst we are on the subject Quote Link to comment Share on other sites More sharing options...
dtm Posted July 31, 2012 Share Posted July 31, 2012 Thanks a million for that mrNick! I was looking for info on this for ages! Do you know does a manta have 0 degree castor as standard? I assume that you move the top wishbone rearwards by inserting vertical washers into the spacer tubes on the top wishbone in order to increase castor? Sorry for all the questionsbut im just about to start on this on my manta. Thanks Quote Link to comment Share on other sites More sharing options...
mrNick Posted August 3, 2012 Author Share Posted August 3, 2012 why cant you cut n paste links in replies ...it's prangging me Quote Link to comment Share on other sites More sharing options...
dtm Posted August 5, 2012 Share Posted August 5, 2012 sorry i dont understand what you mean by cutting and pasting links in replies? Quote Link to comment Share on other sites More sharing options...
