doveyte2800 Posted October 9, 2012 Share Posted October 9, 2012 Hi there, Can anyone please tell me the free length and poundage rate of both front and rear standard springs for a Manta A. Thanks Quote Link to comment Share on other sites More sharing options...
Stev0 Posted October 12, 2012 Share Posted October 12, 2012 i'm actually also quite curious... would be interesting to see what other springs could be retrofitted onto it... Quote Link to comment Share on other sites More sharing options...
tony g Posted October 14, 2012 Share Posted October 14, 2012 According to the factory manual the rates are : Front : No load, 14.8 inch (376mm) Loaded to 8 inch = 950 lbs Wire thickness 12.15mm On another page (very old pages) it says: No load 12.8 inch (325mm) loaded to 7.6 inch = 682 lbs (Im assuming these are the rears) HTH Tony Quote Link to comment Share on other sites More sharing options...
tony g Posted October 14, 2012 Share Posted October 14, 2012 Front 14.8 to 8 inch = 6.8" 950lb/ 6.8 = 140 so maybe these are 140 lb/inch rating? Tony Quote Link to comment Share on other sites More sharing options...
doveyte2800 Posted October 14, 2012 Author Share Posted October 14, 2012 hi Tony, Thanks for that, youve lost me a bit, but thanks. Dont think your assumption on the rear springs is right as they are definately longer than 325mm . Its a start so will keep digging Quote Link to comment Share on other sites More sharing options...
tony g Posted October 15, 2012 Share Posted October 15, 2012 Yes its a bit vague in the book tbh. They quote unloaded (as in free length) then loaded to compress to a certain length 8" in this case and give the poundage once its compressed to 8" Yes the rears are a wrong assumption as you say. Tony Quote Link to comment Share on other sites More sharing options...
tony g Posted October 15, 2012 Share Posted October 15, 2012 doveyte2800, whats your goal here? i can prob take some springs to work and get real world answers with used springs but i'm not sure how relevant they are for your case. Are you trying to get a specific ride height or poundage for an application? Tony Quote Link to comment Share on other sites More sharing options...
monzta Posted October 16, 2012 Share Posted October 16, 2012 Maybe its for the 2,8 Quote Link to comment Share on other sites More sharing options...
doveyte2800 Posted October 16, 2012 Author Share Posted October 16, 2012 hi TonyG, I am trying to calculate lengths and poundage for the next rally car to replace the TE but i need a starting point hence the request for standard info. The ones we had for the TE are far to hard, thus long, to be fitted on a 2.0ltr. Regards Quote Link to comment Share on other sites More sharing options...
