Injection Fuel Tank Help
611
Im just after a bit of technical help on fuel tanks.
Im running full injection with throttle bodies on my A series. Im using the A series tank and have an in-tank pump fitted that has the send and the return on it, but what i want to know is do i need any sort of pressure relief valve on the tank or vent? Is it possible that the tank could get pressurized or the opposite and be sucked in?
and what should i do with the two vents on the top side of the tank as normally these just loop up to the filler neck.
Any info would be great.
Thanks Andy
It's a high pressure one from a fiat punto GT, as I didn't want to have the old setup of low pressure into swirl pot and then high pressure.
So this is a complete unit with swirl pot filter etc...
There are some pictures on my blog www.theopelproject.com
I think I might need a pressure relief valve fitted some where in the tank, but don't know much about injection systems.
Andy
To answer the breather question, I don't have an A series but on both the Opel Kadett C and Manta Coupes, from memory the little breather pipes join into 1 and then exit under the car so there is a way to let air into the tank to stop it developing a vacuum..
From memory also hatch has more of the little breather pipes welded in due to it's weid shape and they all join together and go up to a valve near the filler neck but years since I had a hatch.
If required I'll confirm with pics next week
Hey Tony and mantadoc, thanks for the info, i thought that might be the case but didn't want to find out it pressurised the tank when i do finally get it all up and running :-)
Tony, as you can tell, i still haven't got the car anywhere near running yet! been having problems getting some Goodridge fittings for the fuel line and also decided to get the front cover powder coated and thought i had a spare seal for the front crank, but it turned out to be an axel one :-( so after buggering up the good one that i put in before the cunning plan to get it coated, im now waiting for a new one! Once i have these i might be able to get all the engine back together and wont be far off turning it over :-) I also decided to pull the 5 speed apart to check it was ok, so have that to build back up.
How's things with you??
Andy
