Dom400 Posted January 17, 2013 Share Posted January 17, 2013 (edited) As above, Block - needs deglazing for new rings - measured up within spec with big end caps. £50 Omega 86.0mm forged pocket pistons with gudgeon pins - 500miles use - measure up spot on. £150 New set of Rings for the Omega Pistons £50 2 sets of standard Mahle forged pistons as spares. £50 2 sets of good conrods £50 1 set if SBD conrod bolts - better than ARP £60 Flowed head with cut back valve guides - seats lapped to valves. £250 All Valves - relapped into head £30 1 set of hydraulic tappets £20 New water pump £20 1 set of head bolts £10 Complete head and bottom end gasket set £50 2 cranks an early light one and a later heavy one as spare - need regrinding for new bearing shells. £60 2 used oil pumps £30 Strengthened sump with windage plate £50 Cam cover - been rubbed down needs a paint. £20 Fuel rail with Beige injectors £75 Standard Plenum £30 Standard Throttle body £25 Thanks! Edited January 17, 2013 by Dom400 Quote Link to comment Share on other sites More sharing options...
robah Posted January 17, 2013 Share Posted January 17, 2013 PM sent. Quote Link to comment Share on other sites More sharing options...
czwh42 Posted January 18, 2013 Share Posted January 18, 2013 Pm sent Quote Link to comment Share on other sites More sharing options...
