Spring Compressors?
rutthenut
Recall having difficulties years ago when changing front springs (on Manta B) with normal spring compressors.
The Haynes manual shows a different type, compressing the spring against the lower wishbone.
What do people on here use or recommend, is that type of compressor available?
Should've mentioned, I just have a basic pair with hooks on screwed shafts. I see newer versions available with safety clamps and other features that look a bit betterm though not sure they are usable on springs between the front wishbones.
Wonder if this item would do the job somehow?
http://www.sealey.co.uk/PLPageBuilder.asp?gotonode=ViewProduct&method=mViewProduct&productid=5199&productdescription=spring%20compressor&productcode=&category=6&catgroup=331&catmicrogroup=&analysiscode=&requiredresults=16&grouplevelonly=&fulltext=
Had tried searching the forum but found nothing relevant. Using Google to search elsewhere gave me this link :-o
http://forums.mantaclub.org/topic/29935-what-are-the-best-spring-compressors-to-use/
That advice still recommended, just undo lower bottom ball joint and remove springs without compressing them (and install them that way too)?
