Gearbox Oil
tom child
According to the manual The original from Opel is a SAE75W-85 API GL4.
the box itself is not that bothered about what goes in .my mate is a gm mechanic and they only ever use ATF as mentioned before dexron III will work fine . but you may need to replace your seals after a month or so, the oil is a lot thinner and will leak past a seal that would happily hold a thicker oil.
