Wheel Upgrade
Arkade
Not sure on the offset have 37 on mine, and found that running 15 x 7j on mine with 205 - 50 - 15 on full lock the fronts rub on the valance. It looks ok just sat there when you test lock to lock but when on the move i think there must be a bit of movement in the bushes as they rub on full lock reversing. So you might need to bend the lip up a bit. And depending on how low you go you might need to check the rear arch lip as well.
Apart from that no problems at all :-)
Andy
I would if there a good price. I think its the right size for an A series as if you go bigger unless you get it just right they look a bit like you have just shoved a set of big wheels on.
Not the best pic but mine when it was running with the wheels on.
