Thread Size
Mickfrad
Hi
I am looking for the thread size for a cih oil pressure sender for my gte.
The top of mine has disintegrated due to the heat. Which I understand is normal due to the great, easy to access location.
There are a few listed on ebay with different thread sizes which look like they will do the job.
Thanks
sorry cannot tell you the exact size .however the hole in the block where the elbow screws into is the same size as the oil filter priming plug on the front of the engine(on the side just above the filter)some people just fit the sensor there.it is easy to get at & wont suffer any more heat issues.the original sensor has a much smaller finer thread which fits into the elbow piece so if you could get the old unit out & replace it with a plug you have two thread options to go for .
